andrewwardell
…wait, there’s a shelf filter now?
Yes, both left and right.…wait, there’s a shelf filter now?
Today I have noticed that the Q factor set to 0.53 in the EQ is not preserved after exiting and re-entering to EQ configurationThank you fiio for having solved the filter problem with the latest app uploaded to your website.
Dear friend,Today I have noticed that the Q factor set to 0.53 in the EQ is not preserved after exiting and re-entering to EQ configuration
Great UPGRADE for BTR7.The new firmware V2.02 for FiiO BTR7 is now available!
BTR7 firmware download: Click here
How to upgrade the BTR7: Click here
Hi, Today I discovered another bug in the fiio control application. It is the Bost bal out mode function that if you activate it does not stay ON when you exit and re-enter the application. Sincerely.Dear friend,
Hi, we have reported this problem to the engineer when you mentioned in the BTR15 thread. Maybe it still takes the engineer some time to fix the problem.
Best regards
For me, not even if you switch tab and come back to it, even without exiting and re-entering entirely. From testing with a low shelf filter very high up (at 8kHz), while it shows the shelf on the graph, it's not actually setting it at all. It's only ever a peak filter. This is again, part of the whole problem with the Fiio Control app, it misrepresents to the user what has actually happened. Better if it didn't work just tell the user that. It would make it easier for Fiio to debug too.Hi! There are problems with the shelf filter.
If you set it to highshelf or lowshelf they are not preserved after you exit and re-enter to the application. The filters back to peak.
Regards!
Hi, You need to download the latest version (3.22) of Fiio control app from the official page to fix the filter issue. But they still have to fix some bugs that have already been reported.For me, not even if you switch tab and come back to it, even without exiting and re-entering entirely. From testing with a low shelf filter very high up (at 8kHz), while it shows the shelf on the graph, it's not actually setting it at all. It's only ever a peak filter. This is again, part of the whole problem with the Fiio Control app, it misrepresents to the user what has actually happened. Better if it didn't work just tell the user that. It would make it easier for Fiio to debug too.
I also don't see how it is possible to rename the EQs, they are still USER1, USER2, USER3.
Dear friend,@FiiO shelf filter on the new firmware is not working for me. It at first seems like it has worked, and appears in the graph OK. But when I swap to another EQ or tab and go back (so it reloads them from the device) the shelf filters turn into peak filters. Any tips would be appreciated.
As a note, this is one of the problems with this device, and the app control on all your other devices as well- that there is a certain decoupling between the app and the device. So the app will present a setting as having worked, when they haven't actually been set that way on the device. This makes using them extremely frustrating as you can have no trust as to whether what you did is what is actually on the device. It would be better, if the app fails to set whatever it is trying to set, that the user gets feedback in the app that it didn't work. I know you aren't the only company with this issue, Moondrop has the exact same problem with their DSP cables for example. Qudelix does NOT have this problem, and would be a good example to learn from. I have quite a few of your devices, and they all seem to have this problem that the app doesn't wait for feedback that a setting actually worked on the device, it just sets it in the UI when often it hasn't actually set. Some more than others, the FW5 is much less reliable. But it's a a general app/UI issue, that you need to verify that it actually worked before presenting to the user that it did.
Dear friend,
Hi, please check whether the APP version is the latest version as well? As the working feedback, we will report to the engineer for assessing adding. Thanks.
Best regards
Dear friend,What is BTR7 idle time in BT receiver mode (that is it is connected, but no playing back takes place)?
