itchyears
- Dec 14, 2013
@helmutcheese Quick question, I noticed you also have an Nvidia Shield and PC similar usage to myself.
Do you have any recommendations for a PC BT adapter that may work well with Windows and LDAC I have a rubbish 3-4 quid one and an Avantree DG60 (audio only) both not the best with Windows, Avantree does not work with the A2DP driver since its like a usb soundcard.
I have an Sony XM5 hps with dual LDAC codec so was hoping to keep everything LDAC if possible but not 100% important, so far no real lip sync or issues since my PC and NVIDIA shield are less then 1 metre away from me other then the auto pairing issue which I can manually connect to xm5s anyhow.
