desik
- Jun 29, 2010
Pics.
(image missing)
(image missing)
Right you are. Originals get stiff just like the cable do. Fake stays soft. They are made from different materials.
In my opinion the best fake that I've listened to have close graph shape but with more flabby bass, less detailed sound in whole range, higher level of distortion (with volume increasing).
Guys, here are some pictures of my pair bought direct from Sennheiser Singapore.
Your cable looks exactly like mine, the one I saw at the dealers last night is thinner with a tighter weave (maybe they have the older version?) and I also have a small dot in the foam but to the right.
Do you have any seams on the collars, looks like it's but hard to see.
............. But I also have an RCS800 which is the optional smartphone cable and the weave is identical on that to the wire coming out of the earphones themselves. I would be surprised if they were faking the RCS800 as well
As long as yours looks like this
Yes it looks like this one It came in a ridiculously indulgent Sennheiser box as well that could hold about 20 of those cables! Ridiculously overpriced, but I really wanted the mic and pause button!
Then again....
They were available from...http://www.buychinabulk.com
Guys, here are some pictures........
You can find a tiny hole on the left side of the foam case, just beside the left buds. I have no idea what is that for.
That looks like it came from manufacturing instead of a defect. I have no such dot on my 'rubber'. These IEM's should be nicknamed Scary Situation.
