well to me the iematch only lowered the volume, but on the opposite side you can raise the volume to whatever levels of your source without any hiss, it did not affect the sound signature at all.
yes if you for example listen at 50 out of 120 on fiio x7, then it feels like you are listening at 30, but this can easily be overcome by raising the volume of your source to whatever level you like so if you used to listen at 50 now with iematch you will listen at 70, and you can increase it as you like.
also u can use it with hiss monster amps like alo mk3b which is so powerful and you will barley dial in 10% of its volume with iematch. you will not be able to that without the iematch
its genius what ifi did
The IFI iEMatch is an interesting product. In fact, I'm reading more about this accessory as we speak.
However, even though the product is small and light, it looks as though it might cause some handling issues when used on the go. The part where the cable is connected to the iEMatch will be left dangling.
Still, I'll have a look at this product at my local store. Thanks for the recommendation!
Hello, is there a source that produce no hiss with EE Zeus? Portable one.
My quietest portable source is the AK380. There's no hiss with my Zeus XIV.
