coli
- Mar 14, 2015
The AKM DAC chip seems to be pretty popular, how does it sound compared to the DC-1?
To be totally honest, other than Sabre chips, most "premium" DAC chips sound quite similar - and quite neutral. Because of this, in most cases, things like the power supply, and the other details of the implementation, make more of a difference than the specific DAC chip we use. The DAC chip itself is not going to be the biggest factor in terms of how the entire unit sounds. And so, because our design goal here at Emotiva is generally neutral and accurate sound, and both of those deliver pretty well on that goal, it's going to be rather difficult to characterize the differences - and they are pretty subtle. (I haven't actually compared them directly side by side. However, because the DC-1 is a dedicated DAC, and has a lot more sophisticated power supply, I would expect it to win - but only by a little.)
Looks like Emotiva released a bunch of new products at CES2016, including a new Emersa EPA-1. Maybe @KeithEmo
can get us the inside scoop, but it looks like it features new gadgetry in terms of connectivity:
Any one knows what the specs are on the headphone out of DC1 ?
They don't seem to mention it in the manual
I have this from Keith,
DC-1 Headphone Output specs:
Headphone Amplifier Output Power (from digital sources):
(note: DC-1 has two independent headphone outputs; measurements are for each)
2.5 VRMS max into 10 Ohms @ < 0.01% THD (625 mW)
7.1 VRMS max into 47 Ohms @ < 0.02% THD (1070 mW)
7.26 VRMS max into 100 Ohms @ < 0.02% THD (525 mW)
7.32 VRMS max into 300 Ohms @ < 0.02% THD (175 mW)
7.35 VRMS max into 600 Ohms @ < 0.02% THD (90 mW)
Headphone Amplifier Output Power (from analog input):
(note: 2.5 VRMS analog input required for full output into 47 ohms or higher)
2.5 VRMS max into 10 Ohms @ < 0.003% THD (625 mW)
7.1 VRMS max into 47 Ohms @ < 0.003% THD (1070 mW)
7.2 VRMS max into 100 Ohms @ < 0.006% THD (510 mW)
9.23 VRMS max into 300 Ohms @ < 0.004% THD (280 mW)
9.27 VRMS max into 600 Ohms @ < 0.007% THD (140 mW)
I have tried rebooting the computer but not the amp. I will try starting the computer fresh. Connecting the DAC. Turning it on and see if i can get it. I am going to try it with a PC with windows and drivers to rule out i got a faulty USB on the DAC itself tonight when I get home from work.
I have browsed the forums, there is defiantly issues with the audio usb drivers in OS X El Capitan and a lot of people are having problems with a specific list of DACs. I am not sure what the resolution is but i thought maybe somebody found a workaround. I have two ideas 1) use the optical out on my mac book pro into the optical in on the DAC (though there is only one opt in the rest are other digital connectors) or run dual boot/VM of windows and work that way. Either way I was wondering if anybody has heard anything about this or experienced it with the Stealth DC-1
