I’m not really hearing a lack of resolution that’s being talked about here. It’s not Kublai Khan or anything but it’s more than satisfying me.
Diva is a SICK set. Love it.
In terms of resolution after I've listened to mine for quite some time I think I can try to elaborate a bit. Diva 2023's overall sound signature can be kind of described in one word, clean. It has a very clean sound signature, details are very well cleaned up and gives you this incredible clarity in vocals, but at the same time it cleans out certain micro details that end up making some reproductions, especially for live music, to sound not very realistic, and you kind of lose part of the live feel from it. Overall it makes the sound a bit contained and controlled + slightly artificial, where as IEMs like the Campfire Andromeda are better able to convey that live-feeling. (I've also referenced with my Focal Utopia (old version) and noted the same difference with the Diva.)
For example, the below recording of a live this singer sang in, near the 3:30~5min mark there's a bit where the singer shows a lot of wild emotions and he kind of lets go of the control on his voice a bit, on the Diva while you can get the emotions from the singer it's all kind of still well contained and you can kind of feel the voice wasn't like 100% let out for some reason. It's like you are expecting just this little bit more of a "release" from the sound that the Diva just never ends up giving you. In comparison the Andromeda was not as restricting and lets the voice out, with its faults and recording issues and all. The Diva in this regard kind of masks part of it, which makes it sound more like a recorded song than live. Compared to the Utopia, while an unfair comparison, the Diva was not quite comparable in sounding natural in live performances.
(Note yes I understand this live's pretty poorly recorded and there's a lot of times where the singer actually blows out the mic, but this actually is a pretty good example to show what I was talking about.)
Note that this is more evident in live recordings, and I honestly don't notice this issue as much in non-live recordings. Though sometimes I still do notice that the vocal being a bit more processed and contained than usual, live or not.
Likewise. Cable, source gear and tips are going to make a big difference with this set. Once you have those aligned, it can easily compete above its price.
Maximum bass setting is easily my favorite. The DIVA '23 is an unreal achievement for a 6 BA set.
Yeah, I've noticed that the Diva does change according to sources a little bit, possibly due to its very low output impedance of 4ohms. While the difference isn't huge like with my Campfire Andromeda (that sucker's sensitivity is actually more annoying than anything else), it does pick its sources just a little bit. With the Eros S cable, I find that the Diva actually pairs best with my Cowon Plenue Mk II out of all the gears I have, the bass is much more lively and contains a bit more depth than the other sources I use which kind of flattens it a bit, didn't notice too much difference elsewhere. But this is also in line with what I've experienced with low output impedance IEMs in general, as my Andromeda would sound lean vs sources that has too high of an OI and too bassy vs sources that has too low of an OI. If I remember correctly it likes it best around 2 ohms of output impedance or something like that... Idk what would be the "golden" OI for the Diva but it definitely liked my 0.6ohm OI plenue MK II vs my 3ohm OI plenue P1 more, at least from hearing the bass from both sources.
