Andrew_WOT
- Jan 18, 2004
The bass is just lacking, If you are listening to bass heavy music, the bass is present, but there is no visceral impact so to speak.
How it was before the mod? Try to remove blutack and whatever else you put in there. Another thing, make sure that you install earpads right (left, right, top, down orientation) and that all tabs securely clicked in place. Double check that you didn't block bass ports on top.
They have pretty good, balanced, definitely not lacking by *my standards*, bass, but for bassheads V-Moda is probably a better option.
