Mimouille
Thanks.I've found them here: http://ibasso.cn/?cat=18 There is also XMOS firmware update (DFU).
Downloading Play store apk does not work anymore. (tried, not working)
You need to install Gapps package from opengapps, however it is a zip package to be installed in TWRP or recovery, which the dx200 does not open this feature to public yet.
sorry for the misunderstanding i mean that dx200 is a nice ibasso answer for competitor dap such as onkyo dp-x1which is a japanese DAP,
i'm currently used it but quite dissapointed in the fact that the SE output of onkyo only utilize single dac chip compared to DX200 which use both
I'm seriously considering selling it and switch to dx200 once it landed here
Hello Paul, are there some drivers available to use the DX200 as USB DAC on my computer?
Stay updated on iBasso at their sponsor profile on Head-Fi.
so here are direct questions to @Paul - iBasso
1- can we expect play store to be included in future firmwares
2- would 3rd party apps have full access to the dac without damp sampling
3- would root be possible and install v4a
Enabling Google play store would be nice, but at the same time you are opening a can of worms. Next thing we gonna have dozens of posts with people b!tching about their dx200 crashing just to find out later they installed a bunch of questionable apps. But as someone already pointed out above, you can side load apk, and they are running Spotify on dx200 without a problem.
I don't need Google Play Store to run Tidal app right guys?
what about apps that require confirmation of purchase every now and then like power amp and usb audio player and other 3 rd party apps
now also that defeats the whole idea of making an android dap , as to me android daps should allow installing 3rd party music player apps that have access to the dac
sorry i do not agree with your point that side loading apks is a good enough option
I didn't say iBasso should not enable Play store, I just suggested that if you are after streaming - there is a work around for it. Who knows, maybe Google play store will be enabled. But the fact still remains that it's a double edge sword. Just read X7 and i5 threads... Personally, I would have loved being able to listen my tracks or to stream from Spotify while browsing head-fi on DX200
