Dunu DN-1000 - Dunu's hybrid IEM - Impressions thread
- Thread starter djvkool
H20Fidelity
- Feb 11, 2012
I have a GR07BE for 3 weeks, and its really nice, but maybe I am looking for a warmer, more fun earphone with slightly more bass. Would be DN-1000 a good choice?
I sometimes feel the the GR07 Bass too sharp and not warm.
I am thinking about the EPH-100 too.
I would use with iPhone 4 unamped.
I had a Brainwavz M2 before, and I'd like to get similar bass quantity.
Thanks!
If you can afford it, Westone 3. Or DN-1000 with bass boost of some sort.
Using PowerAmp app or Equalizer app from your iPhone.
nati8056
- Jan 9, 2009
Anyone tried the DN1000 + DX50 how this couple??
Very cheap in MP4NATION
lin0003
- Jan 4, 2013
Yeah, it's a great pairing.
treal512
+1
It's a surprisingly good combo for low volume listening.
nati8056
- Jan 9, 2009
Better than the fiio + dunu dn1000 I ask only in comparison with the dunu
honfoglalo
- Sep 30, 2009
Is the DN-1000 harsh? My main problem with the GR07BE is the harshness. For rap and soul, vocal its fine, but for rock I feel it harsh :S
mochill
Just burn them in long my friend and then you'll hear the glorious biocellulose drivers
JoeDoe
- Apr 12, 2013
No sibilance in the Dunus whatsoever.
djvkool
- Oct 7, 2011
Nothing whatsoever, I hear no sibilance, no peaks, no harshness
honfoglalo
- Sep 30, 2009
Its after 150 hours, and the bass is fine for me and the vocals also, my only problem is the harshness e.g. with Bon Jovi or other rock. Other thing is the seal, its not perfect even with the sony hybrids. You would not recommend the dn-1000 instead? What are the main differences between this and the gr07BE?
d marc0
- Dec 19, 2012
Narrow bore tips will cause sibilance in the dunu dn1000. Try the wide bore tips or the comply tips.
djvkool
- Oct 7, 2011
+1
Absolutely, my theory is that the tip's bore size should be at least equal or bigger than the width of the nozzle, Dunu's nozzle is pretty wide/large so small bore tips will cause some harshness.
Sony's hybrid is medium-sized, what work best for me are Heir/Phillips tips, MEE's single flange, comply TS, and the stock grey silicone, turbine-lookalike one, in fact, this is one of the best silicone tips that I have ever used
honfoglalo
- Sep 30, 2009
Guys, sorry but I was talking about the GR07 and my question was, would be the Dunu better?
JoeDoe
- Apr 12, 2013
It's been a while since I had the GR 07, but if memory serves they do micro detail a little better. The Dunu is going to have deeper bass and better soundstage, so you can pick between those based on your priorities.
