China have always been a mother of inventions, Frank Zappa can be be proud on you. This is an example you can get the best purchase in your life ever... or the worst. .LOL.
Lusya is just selling a black box. On
this link we can find are some photos what is inside. My impression is that there is some newly developed USB receiver chip, so robust that it doesn't need TVS protection diodes, a pair audio ultra-low noise oscilators, but its powerful clock synthesiser is able to generate precise audio timing from a single ordinary 12MHz crystal, typically used for clocking microprocessors. Why do not use RC oscilator instead?
Elementary PCB, but still need a fix with a wire soldered directly to the pins of IC's.
Yeah! I got it working!!!
There is a Pulse transformer or a Chineese clone, not very bad. However it is the same model as on the U2Pro for a coax port. AES/EBU use larger voltage levels, I am afraid, this transformer is not able to create such voltage swing and is not a balanced design. To do it properly, it would require a pair of transformers or chose different model for a balanced output.
Coming back to the receiver chip, it must be some new (unknown) development, marking is removed to avoid litigation from the manufacturer. Yes, a lawsuit - what is going on? It looks like a pre-production batch that didn't deliver a stable product. It should be destroyed, but someone sold it to the Chineese retailers. Some chips only work with 16/44.1kHz source, other 24/96kHz, with a maximum on offer 192kHz. It is why we get different price for exactly the same hardware. At least someone made an effort to manually select a colour. .LOL. It brings a question of long term reliability as well.
