Icenine2
Tubes are what I have w/Woo WA22 and never thought I'd be going there after 30 years of SS. But it sounds great. The more I read the more I wanted to try a tube amp. Life moves too fast not to try different things.
You won't need to worry about it. Just tell Alex C what kind of headphones you'll use. Mine and everyone else's is coming w/a 50 ohm resistor now. This baby will drive the LCD2's big time. Check out the 32Ohm store ALO audio. They carry the amp now (pre-order)
I use a Cardas Clear. It was around $100. I'm not getting into a cable discussion here so I'll just say it is well worth it and I wouldn't even think about going back to a stock cable.
Has anyone compared the W4S DAC2 to a Benchmark DAC1 Pre? Both are up in the same price range, and have variable/fixed line stages with pre-amp functionality. I have the DAC1 Pre, but am curious about the W4S. I run a Squeezebox Touch into my DAC1, then I will be using that as my balanced source for an Eddie Current Balancing Act that is being delivered tomorrowThe Eddie Current will be used as both a headphone amp for balanced HD800's and balanced LCD-2's, and also as a balanced pre-amp for a Krell KAV-2250 amp. So either way, I won't be needing the line stage on the Benchmark or the W4S, and I won't be needing the headphone amp in the Benchmark. I'm wondering if for my money, I could be looking at a much better DAC without paying for a line stage and a headphone amp packaged with the DAC.
The Bench isn't Asynch though.
