DIY: iKEA: Headphone stand/cabinet images. Update 1
Sep 10, 2022 at 6:57 AM Thread Starter Post #1 of 22
OCC7N
In the search for headphone stand and discussion with @bagwell359 I am inspired to share this small project that only need 6 screws(2 hp hangers).
I am awaiting the hangers, when I get them I will start/finish.
Any ideas for lighting/led is appreciated 😊🙌
Sep 10, 2022 at 7:07 AM Post #2 of 22
It'll be nice! If you're going to keep the cover, I'd mount battery LEDs there so they're not visible.
Otherwise, you can do light bars or partial strips in the back with the diffuser covers cut to fit, and drill a small hole to run the wire.
Sep 10, 2022 at 7:38 AM Post #3 of 22
Actually there are holes on each side/corner :)
The battery thing sounds interesting. Im looking for something just on and off switch, no wireless tech or nothing😂🙌
Sep 10, 2022 at 8:19 AM Post #4 of 22
Some have a remote control vs. app. I find those to work better personally and I don't need an LED strip on my network.
Sep 14, 2022 at 1:56 PM Post #5 of 22
Sep 14, 2022 at 2:05 PM Post #6 of 22
Sep 14, 2022 at 2:10 PM Post #7 of 22
link is not working....and I hate seeing the LEDs 🤣
Sep 14, 2022 at 2:15 PM Post #8 of 22
On Amazon, look up LED light diffuser channel. Pick one that you can cut easily.
Sep 14, 2022 at 2:32 PM Post #9 of 22
Check thomann.de for some better headphone brackets :wink:
Sep 14, 2022 at 2:53 PM Post #10 of 22
I cant seem to find those where I can hang the headphones by the metal. Thats why I ordered these actually. Not gonna hang them by the strap
But thomann does have some good ones.
Sep 14, 2022 at 2:54 PM Post #11 of 22
Yes to that!...thats a first thought, everytime I see a LED 🤣 Thanks!
Sep 14, 2022 at 3:07 PM Post #12 of 22
Sep 14, 2022 at 3:10 PM Post #13 of 22
Sep 14, 2022 at 3:15 PM Post #14 of 22
If you can't use local hardware like K&M and Gravity, I think you need to go back to the drawing board on your official design :p
Sep 14, 2022 at 3:28 PM Post #15 of 22
True! 🤣 just wait and see this project is going to be just perfect. But I do need a good headphone stand at the table when I listen at the desk.
Woo Audio hps(from a polish) its a little expensive imo.
