HumanMedia
- Jan 23, 2006
Ok Im home.
The exact controls are:
Pure Direct Select (on front of unit/remote) - this controls turning off the video circuitry, digital outs and front LEDS. The net effect of all of this is substantial.
Source Direct - only accessible from an attached display in the player settings (unless you remember the exact key sequence - learning remote?)) this turns off bass management, speaker distance and levels and turns on DSD decoder straight to analog (no resampling)
Remember that unless you have all speakers of the same volume and distance away, the Source Direct isnt recommended for multichannel music as none of the delay timings will be right. But for Stereo playback regardless of setup its the optimal setting.
ALSO:
I know the well endowed Welly Wu recommends the 2910 over the 2900, but if you dont need the bass management/speaker volume and distance settings, or only listen to stereo, then the 2900 has superior audio circuitry all of the way through and the analog stages are closer to the 3910 than the 2910. So if you have these requirements and are only using it for audio, the dirt cheap 2900 is a superior audio unit.
ALSO:
