Hi all!!!
Great news. I fixed my Denon D2000 headphones. And now, and now, (and now - distant), I can truly appreciate them (and contribute meaningfully to this thread!!). =).
I am so happy.
I'm including an image of the drill bit / screw bit I used to reattach the small screw - which I found luckily on the floor when it fell out, along with the washer. It was a Number "1" drill bit for 39 Cents at my local Hardware Store in Rochester, NY affiliated with Ace Hardware called Mayer's.
I bought Loctite too in case it wiggles out again. It was kind of difficult, but I propped the headphones up so the screw opening was exposed using my legs sitting Indian style on the ground with a clean (think surgical) paper towel. The drill bit is a tad too long. But at an angle, I was able to turn the screw enough to get it tight in there, in small little turns... I noticed I did mark up the left cup ever so 'slightly' - or was starting to, so I placed a paper towel in between the cup and gimbal to finish it. The mark is hardly noticeable and is surface based - looks like a convex slightly shiny worn area.
If you can find a smaller drill / screw bit that'd be best, or cut your drill bit down with a hacksaw. Apparently the Ace Hardware guy had not heard of an offset precision screwdriver, and that would have been way more expensive than buying a 39 Cent piece.
I'm just glad I was able to get the screw on at an angle.
Here's the picture of the drill / screw bit: http://cl.ly/image/2N2M320B1U35
I'm rocking them out again. My favorite albums (in addition to Dark Side of the Moon): jj - Kills, and AraabMUZIK - Electronic Dream (Deluxe Edition - 6 extra songs).
Great dark / light / love music.
Denon, I love you!!!!
Kevin / kelvanE
