yawg
- Oct 20, 2005
Just got these a pair of these headphones for a good price used, and I have to say I'm very impressed. Not a big fan of the stock cables, but I had one of these laying around and it fit with no trimming, so I'm able to use whatever 3.5mm cable I want now:
If you like these I'd suggest trying the BossHifi B8 available via AliExpress. I got them and they are gorgeous. I guess the B8 are the improved Denons, they have a great cable with standard output and better drivers, 50 mm Beryllium type. And they only cost me 71 €, free shipping! Plus they sound great even straight out of my ancient Nokia N8 smartphone. They have a 16 Ohm impedance and very high sensitivity so you don't need another booster amp. Connecting my B8 via my FiiO amp made them sound even less dynamic.
They look like the Denons without the DENON aluminum plates and have the same walnut cups. I guess they come from the same factory that produce the Denons but are a lot cheaper and solved the original Denon's problems (cheap cable and oval connection). They have thicker earpads, too and are a basically a rip-off but the superior headphones LOL.
If you get a chance, try them and tell us about it. Thanks.
