I would say the the D7000 is not as dark as the HD650 while actually have more bass. I find the mids a bit better on the D7000 as they are a bit more forward and more vibrancy. The treble is also better detailed and more extended with a 100% more realistic ability to produce sounds of cymbals and other crashing instruments. If you mean how does the LCD-2 compared to the HD650 you could take everything I just said but change the bass to be stronger than the D7000 and the detail to be higher as well.
The T1 and HE6 are both brighter sounding headphones with more emphasis on the midrange and highs. I can not say exactly which I would consider better because none of the amps at the meet were able to fully drive the HE6 properly or have the right synergy with the headphone. The owner is now looking to get an amp that can drive the HE6 properly and hopefully run the T1 better as well so he can decide which pair he will ultimately keep. Weighing in better physical design and comfort factors he is leaning towards keeping the T1 though.
So LCD-2 is more bassy than D7000? How would you compare these to HD650?
How would you describe T1 vs HE6?
