PinkFloyd
- Jan 13, 2009
I believe it doesn't have an on / off switch as the manufacturer designed it to be left on all the time. If you must turn it off then the switch on the wall is as good a place as any.
have a read of this article too... Musical Fidelity recommend you let the unit warm up for several days before listening to it for the first time... I assume that this unit performs best when warm so just leave it on all the time and let it run hot
http://www.audioenz.co.nz/2001/0101.html
Originally posted by Magic77 PinkFloyd, I have the X-Can v2 as well. I've opened up mine also, and Yes, it is well made and you can't beat the price for it's performance. The only thing I wish it had is an ON/OFF switch. Do you have any suggestions for turning it ON/OFF instead of unplugging it all the time or using a power strip to turn it ON/OFF ?? |
