Axaion
- Apr 24, 2013
Didn't Asus drop support for their Xonar cards, basically making everyone rely on 3rd party drivers for it to function well?
Cant drop support on something you never supported!
'Line In / Microphone In jack: Connects to line-level sources (for example, MP3 players) or microphones with a 3.5mm (1/8-inch) plug'.
Basically Creative are saying that you won't get to use Headphone Mode unless you have a microphone or an MP3 player in the Line In (What); and no mention of Headphone Out or the Line Outs either which actually do use Headphone Mode.
Is Asus support like this?????
screw it. In terms of Headphone Mode/SPDIF question we know it works, even though Creative do not. *Edit* I only ask this because Feg confirmed that it works on the ZxR; but the ZxR (unlike the Z) has it's digital out on a separate daughterboard. Is there a difference - again, I just want it confirmed?
Don't want to order up gear and find it dead on expectations (aka DOE).
Unofficial new modded PAX drivers for both the Z, Zx and the ZxR.
SBZ, SBZx:
http://www.hardwareheaven.com/pax-drivers/223162-pax_sbz_cd_l13_1_00_22_2013_v1-00-official-live.html#post1493103
SB ZxR:
http://www.hardwareheaven.com/pax-drivers/223163-pax_sbzxr_cd_ld_1_00_22_2013_v1-00-official-live-driver-does-work-now.html#post1493104
Well done Mr Robert McClelland
Not meaning to be in anyway contentious, but Creative sent me this just now:
Should I mail them back and tell them that they are wrong; screw up even?
Actually no John. I believe you have made a number of mistakes that are
misleading. No offence mate (you've been very helpful) but if you could
kindly respond to these questions from your previous email:
1: (John) "Under the Sound Blaster Z PRO Studio Control panel: speakers
/ headphone tab you have two option to select your connections, speaker or
headphone, Please note that the headphone option is only available if
connected to a Line in/ Mic in jack".
John no.... basically what you're saying is that you won't get to use
Headphone Mode unless you have either a mic or MP3 player attached to the
Line in/ Mic in jack. Seriously plain wrong. You did not mention the
Headphone Jack nor the Line Out jacks which would be the correct way of
using headphone mode.
2. (John) " Which means that if the SPDIF connection is used your setup will
be recognized as speakers even if your used your headset, this will be in
stereo mode.
John.. people on the forums actually CAN select Headphone Mode using SPDIF,
and CAN actually use headphones via a 2 channel headphone DAC/AMP. Where
were you told this?
John, please escalate this if you haven't used this hardware before personally;
also please acknowledge that you got this reply.
Many thanks John,
Jamie.
