Bloodflowerz
- May 19, 2009
Sorry for the dumb question but where are you acquiring OEM SB-z from? I've only ever seen retail boxed versions for sale in the UK and Germany?
I'm a bit confused. So it was proven that SBX through speakers does not sound like SBX through headphones?
Yes, you could have asked me about that too, I thought it was clearly audible for every1. Speakers / 5.1 speakers won't sound the same as headphone HRTF with SBX, headphone HRTF sounds much more accurate positioning wise if using headphones.
You can simply run the demo SBX clip with both configs to verify, it's not that hard to notice the difference...
With 5.1 speakers the default 67% worked best (still not as good as using headphone) but with Headphone for me personally, 91% surround works best (tested mainly with UT3 while running windowed mode, tweaking in realtime).
So yea if you are using SBX with headphones, then headphone speaker type should definitely be used.
By the way, you aren't using Generic Software device in UT3, right (it sounds like you are though)? SBX should get disabled in that game if you are configured it properly. If you are using SBX in it, you are seriously reducing the processing there. You should manually put correct device name in config file.Yes, you could have asked me about that too, I thought it was clearly audible for every1. Speakers / 5.1 speakers won't sound the same as headphone HRTF with SBX, headphone HRTF sounds much more accurate positioning wise if using headphones.
By the way, you aren't using Generic Software device in UT3, right? SBX should get disabled in that game if you are configured it properly. If you are using SBX in it, you are seriously reducing the processing there. You should manually put correct device name in config file.
I like speaker SBX mode than headphone SBX because the speaker mode has much wider sound stage. I can trade some accuracy for sound stage (and IMO better sound overall - although the main reason is that headphone out is just so damn loud). I keep the SBX slider at 15% and I only use SBX in Skyrim because it is bugged in standard stereo mode.
Dear Jamie,
Thank you for getting back to us.
Under the the Sound Blaster Z PRO Studio Control panel, speakers / headphone tab you have two option to select your connections, speaker or headphone.
Please note that the headphone option is only available if connected to a Line in/ Mic in jack.
Which means that if the SPDIF connection is used your setup will be recognized as speakers even if your used your headset, this will be in stereo mode.
The gaming setup that you wanted actually will depend on the headset that you will be using, Some gaming headsets supports optical connection.
If you have further questions, comments or concerns please include them in your reply. Thank you.
Best Regards,
John
Creative Worldwide Customer Response
