Loquah
Sweet dreams of Crack, Jamie
Pretty sure that this one will do it from Jaycar: http://www.jaycar.co.nz/productView.asp?ID=PS0192&w=6%2E5mm+stereo&form=KEYWORD
The only question is whether the Crack needs a switched one or not. This one isn't switched, but there is an equivalent, switched one for 40c more. I think switching is only required for shorting speaker outputs like on the S.E.X. Here's the link for the switched one though in case you need it: http://www.jaycar.co.nz/productView.asp?ID=PS0190&w=6%2E5mm+stereo&form=KEYWORD
Looks great. Can't wait to read your impressions of the cap upgrade.
I still need to add some insulating tape to the cap leads and connecting wires, I will pick some up on Monday I'm a bit to worried about getting my hot air gun to close to use heat shrink sleeving.
Jamie, did you get the caps in the UK?
For $200 to $300 DAC, what should I get for my Crack and HD 600. Thinking of ODAC for it's neutrality and give the rest to Crack to color etc... But is there any good DAC, perhaps better than ODAC?
