I had been watching this lot of 6080's on ebay for the last week they had been around $15 and ended up going for $358.40 which still looks a good price but more than I wanted to give to try one for rolling in the Crack
Crack;Bottlehead OTL
- Thread starter ironbut
palmfish
I have to admit not reading all 3500 posts in this thread...
Like many, I would be using this amp close to my computer. Are there any issues with interference from lack of shielding ("gravity mounted" wooden chassis)?
I did get interference placing my Crack next to my Squeezebox Touch. I moved it 3 feet away and it's fine now.
PTom
- Oct 20, 2013
What's a reasonable price for a second hand BHC with a speedball upgrade? Is $550 too much? I don't think I'd be able to build it myself so I'm looking for an assembled one .
MattTCG
- Jan 22, 2012
I posted an ad here and asked for someone to do the build. I got lots of responses. Your price is in the ballpark.
ben_r_
Wait huh? 8 6080s for $350?! Arent they like $10 each from Bottlehead?
GrindingThud
- Dec 11, 2012
7 of them are the nice super heavy duty graphite plate tubes.....worth $50 to $80 these days if you can find them at all.
Nic Rhodes
- Jan 17, 2013
yes I was outbid on these!
Me as well at I was watching 4s to the end it went from US $107.00 just as I was placing my max bid of $160 to US $358.40
Quiet rare to see that many of the Bendix slotted plates together.
Guess we were all hoping no one else had noticed them lol.
ben_r_
Jeez, thats a lot of money for 6080s IMO just for a better build quality. Save up your money and get a 5998 and be done with it. Thats what I did.
Nic Rhodes
- Jan 17, 2013
mine was the $107! missed the TS earlier as well
Sorry about the TS if its the ones that ended 30 Dec, 2013 17:18:54
PTom
- Oct 20, 2013
What was the range of prices you were offered? Also without the speedball upgrade got any ideas how much a second hand one goes for?
Don't you think it's bit risky paying so much since I'm guessing there's no warranty?
MattTCG
- Jan 22, 2012
Let's take this to pm. ^^
Does anyone out there with a Crack and installed Speedball have any noise or hum when the volume is turned up say 75% or higher? I have a bit of noise when the volume pot is up that high and I had my buddy bring his over and he has no noise but a humming sound at that same volume level. Now I know there is no way anyone who isnt WAY hard of hearing would ever need to turn the volume up that high and yes both amps are dead silent until you get to those high volumes, I was just kinda wondering if anyone else's did the same thing. Oh and these effects were heard in multiple places around my house to eliminate the possibility of external noise, with and without a source/RCA cables plugged in and I even removed my Speedball and put the Crack back to stock on mine and it was dead silent all the way up so I know the slight noise at 80%+ volume on mine at least comes from the Speedball upgrade. All voltages and resistance checks look good with Speedball in and I have been soldering for well over 20 years so I know its not a build issue. I suppose it might be one of the components in the Speedball boards but I just wanted to ask around and see if anyone else was experiencing the same before I worry any further about it. As I mentioned its only with no music playing and the volume way higher I would EVER turn it up to.
OK I have some new info on this which may or may not be of help in your case but it worked for me.
I removed my resistors from the rca inputs to bring my BHC+Speedball back to stock my hum was still present, I messed about turning on and off equipment methodically disconnecting listening etc no joy.
Today I moved the Crack downstairs and had it connected up to the turntable (sounds sublime) but still had hum at way above listening levels. Later I moved the crack back upstairs connected up and the hum has changed. It was intermittent something had changed at first I thought it might be tube related but after changing a few it was not. The hum seemed more microphonic related as it started when the volume was turned up past half way but if you let go of the volume knob after a few seconds the hum decreased.
Here's the thing my Crack+Speedball is dead silent now at all levels.
The fix,
I twisted my rca input cables together that run from the dac to the Crack and made sure they where routed directly away from the transformer.
It was that simple! I just happened to noticed when I reconnected I had a twist in the cable and as reached across to turn volume knob my elbow sometimes would move the cables. I wondered about how the internal input wiring is braided to help cancel out interference. So twisted up the connecting rca cables and no noise.
Hope this helps you as well
Nic Rhodes
- Jan 17, 2013
not those but I think I was a bidder, there were 8 from the same seller as the Bendix 10 mins earlir...
Total: 16 (members: 1, guests: 15)
