Very nice write-up, Brooko. Thanks!
Stay updated on Sennheiser at their sponsor profile on Head-Fi.
Excellent review, I loved it.
Just FYI, I think the HD800 cable is SPC, not OFC but I could be wrong.
I also read some previous comments about the pads wearing out and personally I haven't had any issues with it at all and I have seen some pairs that are over 2 years old that don;t show physical wear, but the pads are softer.
And another thing is I hear that it is very hard to remove the pads, so do be careful if you replace them.
Yeah maybe I was using it too often. It is easy to remove the earpads & headband pads though, I removed the ear pads to clean the dust filters about once per 3 months. Here's a couple of videos I found on youtube of someone removing the headband pads & earpads.
I don't think the stand is the culprit here as I'm using the Woo stand for the HD800, which applies no pressure at all to the earpads unlike the Omega stand.
Yeah, it's odd, because I can see how the pads would become softer because it is continuously being compressed, but it shouldn't wear them out unless they keep rubbing on something.
How do you find the DAC1 with the HD800? Not too analytical?
I found the amp circuitry to have its own sound which allows the benefit of using a variety of sources without too many differences. This is a good thing at the price level.
I'm not in a position to analyze DACs actually, cause just like what Purrin mentioned here: http://www.head-fi.org/t/650510/the-new-hd800-impressions-thread/12615#post_10774632,
I found very little differences between DACs with the Senn amp. Now that could be a good thing, or a bad thing depending on how you look at it. I compared 4 DACs when getting the DAC1 (Arcam irDAC vs MF M1DAC vs Benchmark DAC1 vs my DAC at that time, Cambridge DM100) and found very little discernible differences between the DACs with the Senn amp.
I do find the irDAC to be the smoothest sounding while the M1 DAC to be a bit harsh at the top end, but IMO the DAC1 seem to present the largest soundstage. It is a bit bright, but not harsh like the M1 DAC.
I do covet the M51 actually. A lot of people seem to rave about it, and no one hates it, but I'm not sure if getting one would be a good idea considering how little of a difference DACs make with the Senn amp.
I do not think anyone can go wrong with the HD800s. The question is how much you want to spend to let it scale up.
