audionewbi
- Jan 24, 2010
Going from your posts I'm assuming you have the C4 unit? Please share your thoughts on the sound quality.
C4 has always been a player I've wanted to try.
I love to but the darn battery does not want to maintain charge. It sure is charging but as soon as I disconnect it gives me low battery error and shuts down.
From the 20 minutes that I listening USB charger with the T5p I like it a lot more than AK120 with that particular headphone. But that is sound wise only, C4 requires a lot of patient. I did not mind the UI but it is very annoying considering that it does not order the files added on an alphabetical order but instead using the the date it was imported on the devices.
The memory size pair with the 64 GB micro-sd is enough for me and if I could get the battery to work I think I am willing to work around those things if the sound is still the same over the long term.
Hopefully more impression to come but if the battery does not work I think I am sending it back and probably ask for a refund than a replacement and just wait for the colorfly C5 due at june.
