gvl2016
- Oct 18, 2016
One scenario when it will compress is casting from Chrome.
The Chrome browser casts compressed audio. Chromecast Audio itself tries to play at whatever resolution it receives, up to 24/96.One scenario when it will compress is casting from Chrome.
However, I've always experienced stuttering whenever I've tried casting 24/96. It works well for me up to 24/48. Others have reported the same experience.
Truncating 24 bits to 16 bits is not compression, it is downsampling. Totally different.Chrome will compress even if it plays uncompressed, at least in some cases as evidenced here: https://audiosciencereview.com/foru...ents-of-chromecast-audio-digital-output.4544/
Truncating 16 bits to 24 bits is not compression, it is downsampling. Totally different.
Aside from that, ASR was casting via the Chrome browser. I don't use that, because of unreliability and stuttering. I use UPnP exclusively and have no trouble streaming 96/24.
24 bit to 16 bit is called downsampling. Simply truncating will cause ugly distortion. Dithering removes the distortion, which is surely what the Chrome browser does. The simple solution is, don't use Chrome for casting audio. I use BubbleUPnP and QMusic.16 to 24 is neither truncation nor downsampling. The ASR result is clearly compression. Casting from Chrome is just an example when compression can occur.
Are you using files stored on your android device? I tried using UAPP to cast Tidal and Qobuz but couldn't get it to workHello everyone, for a few days now my Chromecast Audio has been transmitting from the Usb Audio Player pro app up to 96 khz without interruptions.
Did you have the same experience?
Stay updated on iFi audio at their sponsor profile on Head-Fi.
I don't know, I'm a common listener, I can only judge from what I read on the Topping E30 and what I hear in my ears.I don't use Chromecast, so let me ask whether there's anything unusual about this bitrate? Was it unsupported thus far?
