Originally Posted by Rob Watts View Post
Component count is very important for transparency. Doubling the number of parts in the direct signal path does degrade depth perception and detail resolution.
But there is another problem with balanced operation. Imagine a balanced differential in, differential out amplifier. The input stage is normally a differential pair (maybe cascoded) with a constant current source. Now the input stage is free to move up and down to accommodate the common mode voltage - but the input stage common mode impedance is non linear, and if the common mode voltage has a signal component (it always will have due to component tolerances) then this will create a signal dependent error current, thereby generating distortion. Unfortunately, the negative feedback loop of the amplifier can't correct for this distortion as it can't see the error on the summing nodes. So there will always be a limit to the performance. With SE operation, this problem does not occur, as the differential input stage is clamped to ground.
Now DAC designers are well aware of this - that's why all high performance DAC's use two single ended I to V converters from the current OP of the DAC's, then use a differential to SE converter to create the voltage OP. There are other reasons for doing this as well, as the DAC requires a very low impedance virtual ground for low distortion, and you can only get this using dual SE amps - another problem is RF and its much easier to decouple SE than differentially - this in turn creates a lot more noise floor modulation, making it sound less smooth.
But for me the most important is transparency. I had an amp that had two modes - differential or SE - listening in balanced mode flattened the sound stage depth dramatically,and it sounded harder, less smooth. That said, there are circumstances when balanced operation can be better than SE, for example when you are looking at connecting a pre-amp to a power amp, and what is best depends upon particular circumstances. In short, if SE operation is noisy, try balanced.
Rob
