ptjw99
- Nov 21, 2012
I'm using my Mojo daily with a DX50 via Coax and a pair of Sennheiser HD-25s and I'm getting maybe only 5-6 hours of use before the Mojo battery gives up. I charge it while I'm at work using a 1A charger for maybe 2-3 hours and it is enough for the indicator light to go green.
Charging it fully takes maybe 4 hours before the light turns blue, but I would get about the same number of hours of use (5-6 hours) and that's not fantastic.. I listen typically at a volume where the balls are double orange or yellow most of the time.. is this typical, or is my battery not doing so well?
Also, I've read many many posts here and I know it is normal for the Mojo to run warm, but is this due to the nature of the power supply that it generates a lot of heat, or because there is a tonne of processing being performed by the FPGA? If it is the nature of the power supply then wouldn't that mean it is highly efficient as it is just bleeding off energy by converting it to heat? No other device I have generates so much heat, but it does help warm my hands on a cold day
