I've found that I set my Mojo significantly higher when using it with JH custom Angie's. So I've made some crude (but direct) measurements.
Source: AudioTest on a Mac Mini sending pink noise at 0.0 dBFS
Measuring: AudioControl CM-20 calibrated mic > iAudioInterface2 > iPad Pro. The mic was as close to the earphone as I could get it without actually touching.
Ambient noise was around 35 dB (A Weighted).
At 40 clicks up from 0, I measured less than 80 dB (A Weighted).
I thoroughly cleaned the nozzles on my Angie's before the test.
I realize that this is by no means a professional test, but at least I'm doing a direct measurement with calibrated equipment. Estimates by
@x RELIC x
and
@Arpiben
were based on theoretical calculations. But my results are very, very different, so I'm wondering what I did wrong...
(Hey Guys! If you can see ways I can conduct a more accurate test, PLEASE let me know!!)
