rkt31
- Oct 14, 2014
i found that hugo's normal volume range (say 8 to 10 o clock on a typical integrated amp) is between azure and indigo( 1 to 2 volt of hugo) with the lowest gain setting of ahb2 power amp. in case of lower volumes like in some movies hugo will have to be at violet (3 v) . this will depend on speakers too but with kef r300 it is just the right set up giving the best s/n performance both for hugo and ahb2. ahb2 is touted to be one of the quietest ss power amp (for the money). the results with hugo are no doubt are very special. this amp suits the hugo's clean output very well. like hugo the amp is neutral and totally grain free. the best part is the imaging which was already very good on hugo but ahb2 is much better than exposure 2010s2 in portraying the hugo's ability. like rob watts said earlier feeding hugo directly to a power amp improves the transparency.
