Ultrason ED5's are not a very hard headphone to drive well like a HD800 so I would say that was one of the many reasons. hth
well, not so easy to drive. Less efficient than my LCD-X or TH900.
Who really knows? It's good news for us Hugo owners haha .
But I think that a big part of the improvement that Chord has made to the TT over the Hugo is the galvanically isolated USB so I think testing with a computer using the USB input would make the difference more obvious (it's just my guess). Or it may be the headphones, recordings, mood of the day, and lots of reasons.
Many here comment on the micro USBs on the Hugo as being somewhat fragile. I've never used them but I am concerned if I do I'll end up having troubles. Any comments on what makes these connections troublesome would be greatly appreciated.
The only issues other than it being a small connection is that of the cable connection itself. The stock that comes with it are loose, I found cheap and expensive cable replacements that are snug fit. However you don't need to look for problems where they don't exist, so just stay calm, carry on.
This issue was because, usb port were soldered to the PCB, but not re-infoced against the port openings of the chasis.
All port openings in the chasis are larger than the ports itself, while this aids in heat dissipation, not great for ports longevity.
Some first gen owners reported usb ports breaking off the PCB. Chord addressed that by re-inforcing the usb port on the PCB itself.
I've been running Hugo TT for 2 days ,I found the depth and imaging becomes noticeably better .I used beyer T1 and lcd 3F . you should try it with Hugo too .
I sold Hugo and still have Hugo TT .
