ALRAINBOW
- Oct 5, 2012
Yes his stuff is very good
I use his stuff
I use his stuff
What is the best bang for buck USB 3.0 Pci Express card you can get and power supply?
Do you think this offers good value for money?
http://ppaproduct.blogspot.com.au/2013/07/audio-grade-usb-30-pcie-card.html
Question: does the revised version of Hugo still come with a square cap on the TOSlink port? I ask because it was not in my box when I purchased my ex-demo model. Thanks.
That's the one i would recommend. Cards by SOtM and JCAT are a lot more expensive.
Power supplies: seasonic is good. But read the test for the ripple figures. If you want to go linear consider PPA and HD-PLEX. And you should really consider dropping the Z97 mobo in favour of a B85 mobo. Far less busy and noisy.
Hi Pepsi,
For your card in post 6546, how to supply 5V battery DC?
Either through some DC ATX converter from HD-Plex or Pico or you diy your way to hi-fi heaven. If you specifically want batteries, try Anker. Some niche manufacturers like Sonore, Teddy Pardo and SOtM make dedicated linear supplies for Audio.
I tried this tweak with my ipod touch/ckk http://www.whathifi.com/forum/hi-fi/usb-dac-power-tweak
And the Hugo could not detect usb input so my unit needs 5v to wake up
Mine is 20XXX serial #
