ted_b
- Nov 27, 2003
I just read PP's page, and I strongly recommend get a regular old USB cable.
What did you think of his cables when you heard them?
I don't know for sure, but hugo doesn't need the power as it has its own battery. However usb standards need power for initial sync. So my guess is that you need to have power leg in for initial plug in and can take it out afterwards (assuming your usb cable can do that)
You cannot take it out afterwards. Both Rob (and my reporting of my other Rob chats) stated that you can't fool it. Once it no longer senses a current the port receiver shuts down.
Anybody experienced instability using the SD USB + Windows 7 default driver + Foobar (wasapi push or event). I used this combi and encountered "unrecoverable errors" occasionally.
Now using the HD USB and Chord's driver and so far it has been stable for the past hour.
As I'm listening to mostly cd-ripped ALAC's, so thought that there was no purpose using the HD over the SD USB.
Wow that was fast. Getting sample cable from PPA that is Lighting to Micro USB! Hopefully work with ipod/pad/phone without any other adapters/cables needed. I think someone was asking for that earlier.
