Reducing the skin effect with magnets in the described way looks passably plausible to me, although I don't really understand the mechanism behind it. But as it looks like, it isn't a practical method for the normal end user, the more so if you want to take it to the extreme. I'm also thinking of the massive magnetic fields pervading the living or listening rooms, with unknown physical long-term consequences (this although DC fields are generally considered relatively harmless). And then there's the financial factor – and the risk of wanting more and more of the good effect.
If I knew more about the mechanism and the geometric arrangement necessary for the desired effect, I would be inclined to try it myself (several strong neodymium magnets are just waiting in a closet to make themselves useful). However, most likely I will stay with a well-tried cable concept promising to fight the skin effect by its geometry for my next headphone cables: ultra-thin magnet wires (diameter 0.04 mm), 250-500 of them per conductor. I suspect the beneficial effect won't match the magnetic approach, instead it's a more practical and much cheaper solution.
Actually I'm very happy with the sound of my headphones driven by DAVE's headphone out. But only with this device in the signal chain:
Yes, it's what you already might have guessed: a
1/
8"-to-
1/
4" adapter sticking in a
1/
4"-to-
1/
8" adapter. Thus a chunk of metal. Something that high-end manufacturers such as WBT («
Nextgen») try to avoid in their connectors.
With the HE1000 I've had problems with the somewhat stringent treble since the beginning. The Silver Dragon cured it to some degree, but from the HD 800 (which it served before) I know that it carries some of this trait in itself. So it's not something I only discovered with DAVE. But the double-adapter array cured it completely the first time I tried it. I suspected that it was just a smearing effect, making the sound smoother as in more forgiving. In the meantime I tried slightly deviating EQ settings which seemed to make it obsolete – just to discover that it still represents the icing on the cake.
On saturday the left channel of the HD 800 (stock) cable broke. So I had to resort to the unloved DHC Clone (unloved because of its distinct dullness and lack of treble detail). So acting out of sheer necessity I adjusted the treble accordingly, according to the trial-and error method, which improved the sound to an unexpected level. But only with the double-adapter thing in the signal chain it really blossomed. And it doesn't sound like smeared at all, much rather like considerably increased resolution, and much more natural, too.
So I'm ready to believe that the metal chunk at the headphone output has some sort of corrective or compensational or even preventive effect – maybe in view of line reflections. Some other audio mystery.
