SYUN ME-1
SYUN is a relatively new brand out of China with an apparently well known (in China) acoustic tuning staff behind it. The ME-1 is the current flagship, and it is an impressive debut.
Specifications:
- Driver unit: 9.8 mm dynamic driver
- Rated Impedance: 30 Ohm
- Sensitivity: 120 dB/mW
- Frequency response: 15Hz- 22KHz
- Plug: 3.5mm gold plated plug
- Cable: 1.20 mm TPU cable
Build Quality:
- Attractive, flashy design
- Sturdy, light
With its shiny gold metallic coated housing, a quick visual of the ME-1 is striking. A large grilled vent in the back allows a semi-open sound with good isolation. The housing is small and should fit in most ears without any issues. The cable has little to no microphonics, but it is more of a standard wire look and subdued compared to the housing.
Accessories:
- 3 pairs of silicon tips (S,M,L)
- Velvet Bag
For a $100 IEM, this is a bit disappointing. The silicone tips are standard issue and not much better than what you would get from cheaper IEMS. The Hifiman RE-400 came with an abundance of tips at this price in comparison. The lack of accessories makes it seem like less of a value, but then again most enthusiasts have their own special sets of tips they enjoy. I’m all for cutting back fluff in order to lower the buying price, so I hope that’s what SYUN went for here.
Sound Quality:
- Mostly analytical, flat sound
- Can be a bit thin for bass lovers
- Vocals shine
- Big soundstage
- Benefits greatly from an amp
The ME-1 can be best described as a dynamic earphone that sounds like a single balanced armature one. The sound kept reminding me of the MeElectronics A161P BA, but at a more refined level.
The sound is very analytical, which is unusual from a single dynamic driver. Those who like a thick, deep, driving bass will not find it here, as the sound signature remains relatively flat throughout. It does take EQ well, so a good 30% bass boost is possible (and pleasing).
The tuning is centered on excellent vocal performance. Clarity and soundstage are above average and validate the ~$100 price point. The wide soundstage is very reminiscent of the Havi B3 Pro 1’s, although not quite at its level.
The flat sound is both a pro and a con. Highs can seem to be a bit much at times, which is the same problem I had with the A161P. Unlike the A161P, a bass boost can be applied to smooth things out without ruining the sound. EDM and bass oriented music can sound a bit thin as well without that boost. If you loved the A161P, you’ll love the ME-1 as well.
The ME-1 is also a bit hard to drive. Out of a smartphone they are just barely passable. With a small or solid amp, the extra power allows the ME-1 to be driven properly to its full capability.
Thoughts:
I love transparent, analytical sound with the ability to add bass boost as needed without distortion. The ME-1 does this, and does it well. If you like this kind of sound, the SYUN is worth a buy. Recommended.
The SYUN ME-1 can be found at lendmeurears.com
http://www.lendmeurears.com/syun-me-1/
