koreanzombie
- Oct 11, 2012
Hi bhazard, did you get your pistons from ibuygou? I just brought them because all the praise from iemagnet, so if they don't live up to the hype it's all his fault, lol
Is there anything on the box or phones itself to distinguish if it's the pro version?
I'm not sure at all there were two versions of the B3.
Every day I use the Audeo on gray filters and CA Pro330s (studio ciem), so Havi are for me a little too dark. For others, not necessarily.
And I changed standard ear tips to biflange from old SoundMAGIC PL30 - the sound is brighter and more open (for me definitely better). Comfort is also improved.
Maybe it was just a description (or plans), but Havi never actually released two versions of B3, which explains the absence of indications.
After replacing the ear tips I do not feel really bass boost (definitely less then Adagio II).
I have all 3 versions on the way anyway, so I'll be able to spot any differences.
OK, got a pick up note for my Piston's today, it was a reminder! They actually arrived at my local post office January 2'nd, not bad but I missed the original pick up note for som reason.......
Initial impression are terrible as expected, thank you fro the heads up IEMagnet. If I was not warned I would have been very disapointed.
Visual the have all the signs of being genuine. Beside never sending me a tracking number all worked out fine from Ibuygou so I would not hesitate to recommend buying from them. As a matter of fact if they turn out to be as good as people say I will probably order a second pair from them at $19 with the free snail mail
Now burn in!
