Light - Man
You are correct, the N5 andN6 DAC chips in the above chart are mixed up. Also, the N6 runs dual DAC chips.
Another correction for you is the N5 uses the same DAC chip as in the AK380, not the Chord Mojo. Mojo does not use off the shelf DAC chips. They use proprietary code running on very powerful FPGA chips, with a proprietary filter (WTA). There is no way that Cayin would use Chord's tech. Chords amp section is very simple and the reason they can implement it is because of the design of their exceedingly good performing DAC. Just keeping the facts straight.
Thanks Relic! have you got or tried the N5?
I am tempted to buy the N5 but also considering the Ibasso DX80.
I am currently using the Hidizs AP100 stacked with the new Topping NX3 amp.
Any views would be appreciated from anyone who has any experience with the above DAP's
p.s. is there any other new DAP that we should consider?
