regit
- Mar 17, 2015
Reference to posts #1232 and #1235 on page 83, regarding the non-linear battery reading below 20%, now I discovered something about the upper range... I'm not sure if this is actually the first time I observed on fw3.0... my impression is so. On fw 2.0, I'm pretty sure it wasn't like that because a large part of my N5 burn-in (~150hrs so far) was with 2.0, and I have been checking quite regularly and have established a general trend of the reading dropping about 10% per hour. My impression is that by the time 3.0 came, I have slowed down the burn-in frequency and ramped up DX80's, hence I may not have observed the battery level drop trend of 3.0.
Today I happened to check the battery level after running for 6hrs and I was shocked to see 71% remaining. This couldn't be. Unfortunately I didn't manage to catch the battery flat as I was out.
I have since recharged and started another run. As of 5hrs, I'm looking at 76%. If it still lasts 9hrs (means the reading really screwed up big time), it should end around 3am later (1130pm now, GMT+8). I will be staying up till around 2am and will check again. If it is still running, I won't be too worried about the battery's physical condition. But however it would mean a probable issue in fw3.0 compared to 2.0.
Update + consolidate:
- At 5hrs, battery reads 76%.
- 6hr 00min --- 71%.
- 8hr 30min --- 61%.
- Once it falls below 60%, it's speeding up. At ~8hr 40min onwards, it dropped 5% in 3mins.
- 8hr 45min --- 48%.
- 8hr 50min --- 42%.
- 8hr 55min --- 32%, now it's dropping 2% by 2%.
- 9hr 00min --- 17%.
- 9hr 05min --- 5%.
Exercise cut. Stop before player poof lol...
So battery is still ok. Could it be fw3.0? I'm tempted to flash back to 2.0 to try...
Sidetrack... btw how do I export the playlist and later import back? I've been doing firmware flashing for both N5 and DX80 recently and really dreading each time gotta setup my playlist again![]()
Update:
- Flashed to 2.0 and running now. After 2hrs, reading is 91%. Ohno... looks like this behavior unlikely to be 3.0 related![]()
- 6.5hrs --- 70%. I stopped the exercise and flashed back to 3.0.![]()
You are not alone on this. Realise this on my unit as well but not sure what is the trigger or what has changed.
Has been full-charging and discharging but does not seems to help. It is like 60% is now the new 20%, i.e. should put to charger once hit 60% (60% to 20% will drop in minutes and probably will miss this if I were to "catch" 20% as an indicator to charge the unit).
Occasionally, when the unit got down to sub 10%, turning off and turning on the unit made the battery meter jumped to 100%!!!
Hope there is a fix for this in newer firmware.
