PinkyPowers
Reviewer: The Headphone List
Ah. Mine powers itself down randomly. Very annoying.
Don't worry, it is how Cayin implemented USER EQ. I don't know exactly why, but all Cowon players and I own almost a dozen behave exactly like that.
Not sure about that one. Some time ago, when discussion about lossy and lossless was all the rage, I remember reading somewhere that lossy recordings tend to sound brighter and a touch louder than lossless, due to processing and intention to compensate for the part of the sound spectrum that has been lost during conversion. When I've compared, say 160-192Kps files versus lossless or some DSD files, that was exact impression I've had. So maybe, that is the thing that you are hearing. Try to just relax and enjoy lush sound that this baby outputs and maybe you won't even notice small changes between files? Maybe someone else can chime in on this one. All I can add is that I am still on Fw 2.0 and don't feel any desire to upgrade. Maybe this version of Fw introduced some new quirks?Thanks Soundtrap!
Now my second question, is it normal when you play an MP3 at 192kbps 16 bit, with the eq set to custom, then play a flac file, 24 bit, the volume lowers as if a preset eq was running, until you open the eq page, then it goes back to the previous volume? Can I not listen to hi-res files using the custom setting?
Thanks
still no news about next FW. Did they abandon the i5 aready after release of N3?
Please one more thing: If no earphones connected don't let the player start in play mode after booting. It should be in pause mode when starting up.
Hi, i'm interested in buying this DAP, and i've seen many old reviews telling that "the ability to use an external DAC will be added in future firmware updates".
So is this feature working with the last firmware?
I might use the i5 with a MoJo.
Thanks
I think that should be a user defined option. I'd prefer that none of my DAPs ever start playing on their own. I want to be in control of when they play, so I'd set it to always start in pause mode.
Not sure about that one. Some time ago, when discussion about lossy and lossless was all the rage, I remember reading somewhere that lossy recordings tend to sound brighter and a touch louder than lossless, due to processing and intention to compensate for the part of the sound spectrum that has been lost during conversion. When I've compared, say 160-192Kps files versus lossless or some DSD files, that was exact impression I've had. So maybe, that is the thing that you are hearing. Try to just relax and enjoy lush sound that this baby outputs and maybe you want even notice small changes between files? Maybe someone else can chime in on this one. All I can add is that I am still on Fw 2.0 and don't feel any desire to upgrade. Maybe this version of Fw introduced some new quirks?
Thanks Soundtrap!
Thanks
True, depends on your preferences. But it should be possible somehow. It's a bit unlogical that the DAP goes into pause when you remove your earphones but it will start playing happily
if you boot it without earphones attached.
Oh, and as I read replay gain is coming tomorrow for the N3. What about that feature for the i5?
Reading recent posts I wonder if these problems are due to fw2.2? I sent mine back due to the volume control problem and unfortunately, I don't recall if all 4 times the volume became inoperative were after I went from fw 2.0'to 2.2. I'm still looking to get another i5 but I'm worried now about fw2.2.
Q. If on fw 2.2 can you go back to fw2.0 simply by grabbing the .zip file and following the change process described when 'upgrading'?
I've had my i5 for quite a long time now, with latest fw, and no volume jump has happened even once. Though the volume pot sometimes doesn't respond, random occurrence only.
