flashcolor
- Feb 21, 2015
I tried the LC in both my study and bedroom. Same problem.
If it is a ground loop, how to get rid if it?
I will have to try a different DAC. Many times this kind of discrepancy is all about input level.
Stillhart, what are you driving the LC with?
Believe Dan is using the DAC-19. Cheers
I got my LC today and something weird happened...I listen to the amp for about two hours and got a buzzing/cracking noise on the right channel while using my HD800 in balanced...
Does it happened to anyone else?
Anyone using the LC with the HE 560s? ... I noticed that I could quite easily drive the 560s wide open at 1X gain.
For anyone using a Hugo as a DAC, what volumes are the Hugo and LC at for reasonable listening levels? I tried line out (Hugo volume knob glows green) and at about 11 o clock on the LC the volume was too low. So now the Hugo volume knob is dark blue and at 11 o clock on the Hugo and the listening level is better.
No wrong answer there as the Hugo volume settings simply adjust the voltage out, like a variable line out. Whatever level you prefer would be the best level without over driving the LC IMO.
Thanks for that. I just want to make sure the amp is working alright. Haha
Correct! I'm surprised there's anyone in the LC thread that doesn't know that by now! lol I've been talking about the pairing since... I don't know, May or June? And I brought my DAC-19 to RMAF and had it at the Cavalli table with the LC so people could sample it there.
Michael, you're using the Pulse Infinity, right? Any volume issues on your end? Is there a Line Out setting that has to be turned on?
I forget, are you using SE or balanced out?
I'm using balanced out. Can't seem to get the line out working on my Hugo. When I switch on with the crossfeed button pressed the volume knob is green and not light blue like the manual says it should be.
I just turn on my Hugo normally, then I adjust the volume to between light blue to dark blue. Then the volume on my LC is usually around 10-11 o'clock. I find this gives me good adjustment with the HE-500 using balanced output. If I were using sensitive IEM's I would adjust the volume on the Hugo a little lower to give more adjustability with the LC.
This is what I have been doing anyways.
