Steve Eddy
Member of the Trade: The Audio Guild
Aka: TempAccount555
- Sep 28, 2003
It's rather hard to tell exactly because Kingwa is always conflating between SATRI and CAST.
But basically, the SATRI circuit is a transconductance amplifier which takes an input voltage and outputs a proportional current, as opposed to a regular voltage amplifier which takes an input voltage and outputs a proportional voltage.
The SATRI "amplifies" the signal by shoving its output current through a resistor.
If you're familiar with Ohm's Law, you'll know that voltage is equal to current times resistance. So if you have a given current, changing the value of the resistance that current is flowing through will change the voltage across that resistance.
And if you make that resistance variable, then you can use it for volume control.
k
Originally Posted by anetode /img/forum/go_quote.gif What is the SATRI circuit responsible for? |
k
