Originally Posted by fotios /img/forum/go_quote.gif
Hi leeperry. Here i am!
Today, i finished the upgrade of the Essence STX of a friend with three Burson V2 and a gd-audio clock. The card is installed in my PC this moment and it runs very well. I did some measurements with the Virtins M.I. Pro 3.1 and the results was very good. I have improvements in SNR and NL by 5dB approx. although the protective cover of card has removed! The THD+N is almost same like the original (who cares about! the harmonics produced are of the "good" odd order). I have not checked yet the performance at 24b/192Ks, which shows the improvement offered from the new clock, because i must to do a different setup in the measurement software to get trustable results and this is time-consuming. Tomorrow i will post some pictures of the modified Essence STX as well the resulted measurements. Better results obtained when the card is cold.
Fotios
hi Fotios, good to have you here...finally!
so did you take out the sockets and solder the burson's directly?
many ppl have modded the Prodigy HD2 w/ Burson's, and from what I was told the RMAA results were giving very poor crosstalk results(in the 50dB region??)
and there's a french guy who was skeptical to death about the Burson, so he put his hands on one dual discrete v2 op-amp and ran all kind of tests on it...he said that when one channel was loaded, the other one was interacting and killing the crosstalk, he also spoke about utterly disappointing THD/THD+N specs...he called the burson's a plain rip off..
OTOH, that frenchie just wanted to bash the damn unit at all costs..he didn't even listen to it
I've personally given up on the STX because the fixed sample rate in the drivers was really getting on my nerves...I can't be hassled to constantly switch, besides the C-Media drivers are just resampling everything on a permanent basis and were very unstable for me on XP SP3.
this guy made killer bit-perfect/automatically bit-matched drivers for C-Media DSP's...too bad they're not compatible w/ the STX, because they really work like a treat in KS:
cmediadrivers
I'm sure the STX on Linux w/ some proper drivers would be a hell lot better...anyhow, how did the clock improvement go? because back in the days I A/B'ed the STX/ST several times, and the STX had a very messy/blurry stereo image in comparison...OTOH the ST was prolly too agressive to my taste
