sphinxvc
- May 28, 2010
So you have to have a facebook to order from that guy?
Does your ODAC have both 3.5mm and RCA for line-out?
Yes, every bit as so. I have been listening to bifrost and odac for several days. It's not easy to get your ears around the subtlety of the differences. After three days of listening, I would give the nod to the bifrost by a hair. The sound stage is a touch wider and the instrument separation and "layering of sound" both a touch better also. I have to go back and forth several times and really listen for the difference.
Odac is a really good dac and goes head to head with the bifrost. Both are great!!
Headnhifi have an ODAC option that can have both 3.5 + RCA connections in a small enclosure. Check this site for pictures and more details:
http://www.diyaudio.com/forums/head-n-hifi-walter/211577-odac-european-worldwide-pre-orders-17.html#post3067236
Same here too actually, it worked fine on my home rig, but when I took it to work last week it simply stopped working. If I left it alone for a few minutes it would pick up but then after a bit go out again. Confusing to say the least, just like Anax said.
No, my PWD and HD800s kill the rig I'm using w/ the ODAC. See below (all Wav btw).
I was responding to the idea that I've just discovered flaws in my recordings as if somehow the ODAC was some sort of revelation compared to the gear I already own. Most of my impressions have been using the UHA6S via PWD/ODAC/Nokia N8>UHA6S Cirrus DAC w/ UERM.
I've tried all the above except the O2 as it's the third most transparent amp I own behind the UHA6S and Super 7 so there's no point. A friend is using it at the moment since I don't listen to it. I've said everything I'm ever going to say about that amp so there's nothing more to add.
I see, but I wasn't really interested in your opinion of the amp.
From the pictures it looks like one or the other, not both The one on the right is the same as the far left with different color enclosure. The middle has the 1/8 output.
I do want to sort the issues I've had w/ the ODAC first though so I can get a consistent point of reference.
It happened again but this time I was home and was able to isolate it to the O2, not the ODAC. Might just be in need of a charge. For you long-time O2 owners, does the LED still light when the battery is too low to amplify?
