ched999uk
- Nov 18, 2013
My partner wanted noise cancelling headphones so she bought the Bose QC35 (corrected from QC30 Oops) as they seemed to cancel more frequencies than most.
Anyway she has mislaid the cable as she doesn't use it very often. The cable is a 2.5mm stereo jack plug to a 3.5mm stereo jack plug. As I don't have the cable I am guessing it is straight wiring? i.e. tip to tip, collar to collar and screen to screen.
I could order a new one from Bose but at £15 for a cable that will arrive when she finds the original seems a bit silly.
So just trying to make one up from the spares box.
Does anyone know if that is straight wiring correct?
