grizzlybeast
My name is grizzlybeast and I'm an audioholic.
German Maestro GMp 8.35D and GMP 400 are both excellent studio monitors
+1 on the 8.35d..
key term for you.. but I get it. hadn't I had the yamaha at the same time and compared them both a lot a lot then the sony would still be here. The yamaha barely won me over but I find that since it has less midbass hump next to the strong lower mids like the sony does that is it more accurately balanced, less congested and the tones/timbres are more true to the nature of the recording on the yamaha.
but yes monitors are better. but since i also want to really enjoy the music my taste is for less congestion.
Interesting the ATH-M50s are not on the list.
These cans are awesome monitors.
i cant wait for this spirit pro to get here. I have a feeling it may dethrone my yamaha.
I've yet to read even one negative review regarding the sound of those. All the grumbling focused on the small pads. We'll be waiting for your impressions!
Grizzly, the Yamaha is available in the UK at the moment for around £130. That's about 1/3 of the price that the 7520 was before it was discontinued (or what it costs if you buy from the States now). That makes the Yamaha incredible value if it's as good as the Sony.
For a closed model, I'm impressed with KRK KNS8400 so long as one replaces the hard, noise-bearing plastic they call a cable. Besides that, it's a little bright which you can mod with foam under the earpads (I didn't need to). The headroom chart seems quite inaccurate to me in this case.
do you guys think that flat measurements are the most important?
would the shure 1840 be just as worthy of being scratched off because it has absolutely no bass? where as the 1540 has too much?
^rhetorical
Where did you get the idea that the SRH1840 has no bass? The problem with relying on what other people say - is that unless you take their individual preference into account - you'll have a very coloured view of the world. That's why more "reviews" should always state the listeners/reviewers preference. Give a basshead, or someone who is used to orthos/planars, the SRH1840 and they'll call it bass light. Give it to someone who is more used to a neutral can - and they'll tell you the bass is perfectly balanced.
If you wanted an idea of what the SRH1840 sounds like, and have heard the HD600, just imagine an HD600 without the mid-bass hump, and with flatter mid-range, and more 'apparent' detail. I say apparent - because I think the detail is same/similar to HD600 but it shines through more because of the lack of mid-bass hump.
I personally loved it when I owned mine. With the drop in price to sub 500, and the possibility of picking up a used pair for $300 or lower, I'd probably repurchase again.
And no - they have beautifully rendered bass IMO, and would be very good for mixing and mastering - especially because they are so flat.
If you scroll to the bottom of that SOS article you see their top overall recommendations. For closed, they recommend the Sony 7509HD. I still wonder how or why it is that the 7509HD seems to have flown so spectacularly under the radar on Headfi. Excellent studio hp IMO (and that of SOS!). The 7520 is better though.
I really liked the 8400s when I had them at home and recording some snippets BUT I didn't like them for just listening and enjoying music. Too tilted up-top, too cold. But for recording and probably mixing they should do excellent.
I'm actually surprised no one has mentioned Shure SRH940s!!
Yes they are bright and their bass attack is lacking (i.e. not boosted, no slam) but I don't doubt they'd do great in that setting. Personally I preferred them over the KNS.
My list of recommendations would include:
1) Shure SRH940
2) KRK 8400
3) Yamaha MT220
4) MrSpeakers Alpha Dogs
5) Sennheiser HD600s
6) Spider Moonlight Studio maybe...
7) AKG K551
Also, an old read but could be helpful: https://www.soundonsound.com/sos/jan10/articles/studioheadphones.htm
SOS is a good spot. you have to pay for some of their reviews though.
