talmlikeabalm
- Apr 20, 2013
How does the crack with speedball compare to the wa2 with the t1?
I am planning to buy the T1 but won't have much money left for an amp. Can someone suggest a sub $200 amp which can drive the T1 well enough?
I can't think of any <$200 amps that would effectively drive the T1. You need to raise your budget a little more for at least something like the Garage1217 Project Horizon or Schiit Valhalla or Lyr.
If you're "planning" to buy a T1 then I'd recommend getting a different, cheaper headphone that has less-demanding (and more inexpensive) amp requirements. I don't understand why anyone who can afford to get ~$1K headphones would want to cheap out with the amp.
If you're "planning" to buy a T1 then I'd recommend getting a different, cheaper headphone that has less-demanding (and more inexpensive) amp requirements. I don't understand why anyone who can afford to get ~$1K headphones would want to cheap out with the amp. If you're straining a budget, it makes more sense to just get a cheaper headphone so you can put more money into a good amp.
