It sounds like that this particular vt52 cant be used without modifying the BA
I also do not think now that they are drop in replacement and we need some modification.
It will be more complicated as different VT 52's may have different electrical properties.
Trying to do too much may not be a good thing as I will make an error using wrong settings for the
tubes used.
As for the VT-52, best stay clear of them just in case.
@Stavros : Thanks, Yes, I think I will wait for KingStyles or other experience on this as I may not be good
enough to do the modification , test and use this VT52 although they may be very, very good.
Are these Mullard ECC35 's are the one that have the best sounding : short bottle brown base.?
From the picture I am not confident whether they are short bottle or medium bottle
Here is Craig's response concerning the VT52 with the BA The VT52 can be made to work in the BA. It is not a drop in replacement for the 300B. The heater voltage is too high and will require one, or two more turns of wire on the heater transformer, or a new amplifier that will go past 7 volts to drive the existing transformers. The other curious thing about the VT52 is the electrical parameters are different between manufactures. Western Electric has a different bias requirement than Sylvania. So one gets the amp to work with the Sylvania, and now it won’t work with the W.E.. Where does this end, most likely with the TTA
Here is Craig suggestion to incrase the output to drive the more difficult phones: AKG K1000
If you want max driving power replace the 24k plate resistors in the BA driver with 47k. By pass the cathode resistors, replace the 6SN7 with the 6C8G, and re-bias for the PX25. This configuration will drive the K1000. It will have too much gain for the more sensitive headphones, and will loose some of the magic. Everything is a trade, or compromise. Take a deep breath and consider what you really want. Then pursue that goal.
Those are the tall brown base ecc35. They are also very good. They are just a little less warm than the short brown base.
Are they the same as Philips Miniwatt ECC35 because I also have those.
BTW, I have asked Craig specifically that can we try the Sylvania VT52 with 5V filament voltage setting? One of the site of VT 52 also said that we can use the VT52 at 5V and it can also save the tube life and with some
type of transformer it may have the output at 8W
Here is his answer : thay you may try VT 52 , so if you have received the VT52, can you try and share us your experience? You can try the VT52 at 5V. It won’t hurt the BA. No idea how they will sound
That is a short brown base. I havent tried the black base yet. They are a couple years newer than the brown base. They also come in a short black base also. Rosgr I think has tried the black base ones.
I have tried all 4 types of ECC35 with different type getters so really there are more than 4 variants.
Wire getters, inverted pan getters and so on.
I like them all.
