Nostoi
Hi folks, retrieved the DT700 Pro X, so now have them both at hand.
In short:
1. Comfort is fairly similar, though I prefer headband and pads on DT700 (pads especially). Clamp pressure is also similar, though again I would say Beyer is slightly lighter, though really depends on your head size.
2. Portability - no contest, HX60. I have taken the DT700 out and about, used as portable cans and putting them in the standard Beyerdynamic DT770 Pro case. It works, but it's nowhere as ideal as the HX60. On the other hand, in terms of power, I think the DT700 require less power to be driven from a portable source (although both can easily be driven from any modern DAP).
3. Sound - I'm afraid my hunch was right, the DT700 suit my kind of taste more than HX60. There's a sub-bass elevation in the DT700 that renders metal/rock more engaging. The overall profile is indeed, as @plakat says, more forward and more engaging. I would say the HX60 are probably more refined with greater fidelity to the source. You could also argue that the sub-bass and bass in general is cleaner/clearer on HX60, but less "fun" (though again neither headphone are strictly designed for this purpose). The HX60 does have a more airy slightly diffused quality, whereas the DT700 is more intimate. Technically, I don't hear any notable differences in terms of imaging, detail, etc.
I don't think you can go wrong with either headphone. If HX60 released a headphone with same build/design but with DT700 tuning, it would be the ultimate portable headphone. But for now, my own taste leans toward the Beyerdynamic overall (sorry to betray the locals )
In short:
