Nostoi
Super, thanks for this. Sounds promising. Can I ask you how they compare with the DT700 Pro X in the following respects:Look what arrived today
Really like what I hear, there's deep reaching bass with very good structure (could be a few dB more for my personal taste, but objectively its very well balanced with the rest of the spectrum), nice and detailed mids that don't have that slight shoutiness of the Hi-X55, and sparkling treble without sharpness. Had just a few songs played from my iPad through a 1. gen Hugo and the Apple USB-C to 3,5mm adapter, sounds good even on the latter with lots of dynamic reserve. Comfort is top notch, just as with the X55.
Passive isolation is again very good, and it still has that spacious sound like the X55 but sounds more even overall.
I noticed the pads now have holes... this might provide the damping of the upper mids, which were a bit too present on the X55 -- I always wanted to ad some felt inside its cups, but never came around to try that out.
Packaging is as with all past Austrian Audio headphones, i.e. a cardboard box with Velcro -- I still like it. The darker gray looks good with the red accents, and I like the fact that now both the 3m and the 1,2m cables are included -- I ordered the shorter one extra for my X55.
1. Comfort, isolation, and leakage?
2. Technical performance - especially imaging and detail retrival?
3. Any other impressions on how they compare in terms of timbre would be welcome.
Clearly the X60 are far better suited for portable use. The design generally looks outstanding.
Thanks!
