As for this cable, I am starting to tip roll and see if I come up with good matches.
I'll quote myself,
. I did go and tip roll and finish figuring out the AFU cable. Best with warmer sounding tips to counter the extra high end it seems to bring. Much different than the UE cable which has quite a bit more warmth even when using tips that balance out more. Really so different. The UE is like a much, much better DDM1 while the other is like a much, much better RE0. I went back to the UE cable for a solid hour after 5 or so straight getting the handle on the AFU. The AFU cable makes the UE cable sound a bit more out of focus or loose in sound. The treble brings more brightness, high end detail, treble extension, added clarity. The fit with the UE cable started to hurt my left ear and certainly is not as comfy as the AFU cable. I need an S-adapter to add some impedance and tighten up the ASG-1 sound a bit to counter the tighter more refined sound of the AFU cable. This adds 13" more cable which I'd rather not have if I could avoid it.
So, in the end I have chosen the UE cable. The UE cable just has the synergy, the toe-tapping nature. The amazing low end performance and large headphone sounding weight and presence. The same thing that originally took the ASG-1 from second place(and most likely being sold) to my modded TF10 to goodbye TF10 when I first put it on. One hour and again, higher technical ability aside, even on the ASG-1 itself there is no doubt the UE cable is the choice. The sound with the AFU is impressive but the UE is special. Yes, I usually favor the other side, a CK10, DBA-02, two TF10's, two ER4's, RE0 etc. but I am going with the low end biased, lush, creamy, super weighty and hefty sound that the UE cable brings to the table, going back to the more balancing sounding SHE3580 tips, and adding my Ety P->S cable to tighten up/refine things a bit.
Really depends on sources and whether you're going to amp or not. The AFU cables would really pair well with the ZO2. The UE cable really actually sounds like a ZO without the need for the ZO
My results and decision are based on tending away from using any amps anymore. So straight out of my sources, Coby micro-clip(sigmatel 35XX series chip, slightly better sounding than the clip+ for some reason), Sony S639, Hisound Rocco P, iriver E300, and Sony minidisc ca. 2001 S-decoder chip. Interestingly, they cover most of the signatures you'll find from the very neutral/leaner Rocoo P to the very warm minidisc. Certainly the UE sounding more like it is amped is part if it's draw and if I still had the ZO2 it might be interesting to see if that changed anything and is certainly part of the decision when trying/choosing cables.
