lolspops
- Jun 17, 2011
Alright, I understood beforehand that when paired together that they would be very bright but it won't affect me.
Quote:Yes, but I am 100% set on the T1 as well as the DT 880, just deciding if I should keep the Pros, or get the Premiums. You said that they don't pair well but does that mean they sound worse than the Pros with this DAC/Amp?
The difference in ohms between the 880s are very minor. And the difference between the pros and prems are cosmetic thus the 250 pro and 600 prem should sound pretty much the same. Graphs show the 600 ohms being smoother treble wise. The above comment wasn't meant to discourage you, it was just meant to let you know that they power the DT880/600s just fine, just doesn't synergize well. They don't pair well because it's a bright headphone with a bright amp so it exacerbates sibilant recordings so if you're sensitive to treble, you wouldn't like the outcome. But with that said, you can always use the lineout and connect a warmer amp to the T1, which I have done myself.
