YtseJamer
@SkylarGray, That'd be great to know when the new "ultrasuede" pads will be available ?
I'm trying to get those out as soon as possible! Ideally before the holidays.
They seem to be preferred by nearly everyone who has tried them internal to AQ and external.
Can you share the price point for the new pads?
Also the new cable?
I better jump in and clarify/correct the info given...
More info on Nov 1. For now I can say:
- The new Carbon finishes most definitely cost more to produce versus the four clear coats on the current NightHawks. The new finish is an automotive-inspired process that consists of multiple layers of primer, base coats, and clear coats—all automated with a final hand-polish for quality control. We buy the same paint Porsche uses on the Panamera called "Carbon Gray Metallic." It's a near-black shade with a subtle hint of golden warmth.
- We call the new headphones "Carbon" because of the finish, not because of the cable. In our cable lineup, we reserve "Carbon" for digital cables only.
- The earcups are still made the same way from liquid wood. The wood aroma remains.
- NightHawk wood will be discontinued. If you are thinking about buying a NightHawk, I suggest waiting until after our announcements next week.
- NightHawk and NightOwl sound very similar. The goal was for them to be as close as possible. But they are just different enough that I believe it is worth listening to both before deciding if you want one or the other.
- The headphone stand is black so that it will match anything. We might (BIG might) do other colors/finishes in the future.
The Nighthawks Carbon do in fact replace the current Nighthawks but are not improved - sound wise. Only the cosmetic colour/finish of the cups has changed. I called Audiosanctury from where these pictures derive and asked them. The current Nighthawks in brown will be discontinued. It is costly to produce them in the wood finish.
The Nighthowls are engineered for closed audio listening and again are not superior to the Nighthawks, just different. Although base is tighter as often is with closed cans.
The above information is what Audiosanctury stated in conversation today.
Another thought - will the new Audioquest Headphone stand match the current Wood finished Nighthawks and the forthcoming Carbon Colour - Nighthawks/Nightowls.
O_o
Literally every single headphone known for boomy and bloated, overdone bass is a closed can. The closed structure makes the bass tend to have more bloom because it can't dissipate outward. Where on earth did you ever get the impression that closed cans have tighter bass??
